2005 Yukon 1500 starting problem, PCBM fuse keeps blowing
Old 09-28-2014, 11:41 AM
Fynx's Avatar
Default 2005 Yukon 1500 starting problem, PCBM fuse keeps blowing
My father is having problems with his 2005 Yukon, it won't start. He found out the PCBM fuse was blown. He has tried replacing the fuse a couple times so far, he also says his dash lights up and the tachometer is also acting weird. But after he changes the fuse the yukon will run, but as soon as he turns it off and checks the fuse again it's blown. What possible problems could he have we know the PCMB fuse powers the PCM and fuel pump. Could the fuel pump need replaced, or do you suspect its faulty wiring?
DeeDog55
01-03-2014 03:58 PM
jay13
09-09-2010 06:39 PM
95silveradoz71
12-11-2009 08:11 AM
jad20041972
02-07-2009 02:47 AM
tan1320
11
01-29-2009 05:41 PM
Quick Reply: 2005 Yukon 1500 starting problem, PCBM fuse keeps blowing
