Chevy/GMC Heavy Duty Discuss your 2500 and 3500 Chevy and GMC pickups as well as the DURAMAX diesel and it's predecessors
tapping IGN slot on fuse panel ??
Old 06-10-2017, 01:14 AM
Bren Sage's Avatar
Cool tapping IGN slot on fuse panel ??
Hey all. So I am driving a 1995 gmc rally van g3500. I have dual batteries set up and all ready to go, it works and charges and everything, woop!
My battery isolator relay needs its own 12v power source to close the circuit and connect the aux battery. (edit this has to be a "true ignition" source so it has to be hot when the key is in the crank/run positions) I found a wire that had alraedy been hacked by the previous owner and tapped into it, sure enough I picked an ignition wire! Lucky me! Problem is ...
i went out on a drive once it was all stitched back together, put on the turn signal and heard clackclack! from the relay every time the flasher blinked So yea i need a better wire .... hehehhh
anyways. So i'm going to do one of two things. I'm either going to get a fuse tap connector; or, There are empty slots on my fuse panel for ign/acc/bat. So i could just tap into that empty IGN socket. I'm just not sure what kind of connector I need to tap into that socket! It looks like it needs some kind of block/molex type connector. Does anybody know how I can tap into that by chance?
many thanks! -b
steamygrave
12-14-2011 03:36 PM
chrisrokz05
01-19-2009 05:28 PM
mista E
08-07-2008 09:03 PM
mavericki8r
05-15-2008 08:56 AM
72charger
03-30-2008 05:52 PM
Quick Reply: tapping IGN slot on fuse panel ??
