No Brake Lights or Hazards
I have a 94 chevy stepside, 2rwd, base. I have no brake lights. I researched the forums, and discovered I have no hazard lights as well. Checked all fuses and ground on rear driver's side frame. Could this be the result of the brake lamp relay located right above the brake booster ? Having no hazard lights front and rear would tell me it's not the brake switch under the dash. Would this be true ? Or is the hazards on a different circuit ? Besides, I just replaced the brake light switch a year ago. I have tail lights, backup lights, and turn signals. Any input will be appreciated.
Thanks in advance.
Thanks in advance.
Thanks for the reply. Replaced the relay and now have flashers. While troubleshooting this weekend I notice a second yellow in the harness coming from the front not inserted into the 4 wire connector. (Yellow, Brown, lite and dark green). As should be. Just hanging loosely in the wire loom. Now this harness has not been molested as I bought this truck new. So what's this additional yellow wire for ? Is this an auxiliary wire for towing ?
Thanks in advance
aub1027
07-20-2006 10:25 PM
