1976 Sierra, fuel delivery issues - Truck Forums
Reply
LinkBack Thread Tools Search this Thread
Old 08-24-2010, 01:09 AM
mescalito's Avatar
Default 1976 Sierra, fuel delivery issues
I suppose I'll start at the beginning. The truck has been sitting for a couple of years with little attention. I recently rebuilt the carburetor and noticed the float bowl was bone dry, so I assumed the fuel pump had gone out and replaced that after I finished the overhaul. After priming the carb a few times with a small amount of fuel, it would start for a few tantalizing moments before cutting out. I detached the after-pump fuel line and situated a catch container underneath it and started it a few more times via the priming method and still nothing, although the pump seemed to be trying to do its job.
I'm not sure if this is related, but the fuel gauge is screwed up in such a way that when the tank is empty, it reads at a quarter full. So as you add fuel it always displays a quarter tank more than is actually in the tank. I haven't taken it off to inspect it yet, though I presume that the sending unit is at issue.
thanks in advance for any input
Old 08-24-2010, 01:57 AM
RUFFNECK4LYFE's Avatar
Hmmm think maybe the fuel line from the tank is clogged. Try the reverse of what you did. Use a 1 gallon tank of gas and see if the pump pulls fuel from that when cranking.
Old 08-25-2010, 12:22 AM
chrisbmo2000's Avatar
WOW!!!! havent had my hands on one of those motors in awhile.......the fuel gauge problem is probably the gauge its self they were known for doing that very thing....as far as fuel delivery.....I say pull the tank and check it out the sock filter could have a bunch of rust built up on it....while you have the tank down diconect the fuel inlet to the pump and the outlet from the tank and blow some air through it with an air compressor (not real high pressure....20psi should do) it could also be the pick up is clogged to......on a side note did you get the pump seated right on the crank? that was another common mistake.......just some ideas
Old 08-25-2010, 08:05 PM
mescalito's Avatar
At ruffneck4lyfe's suggestion I ran some tubing from the tank-side of the pump into a gallon gas tank, and it pumped just fine so I think I can rule that out. I haven't dropped the fuel tank yet, but that is my next little project. Most of the steel line between the tank and the pump looks good, but some of the short rubber segments appear due to be replaced.
I appreciate the ideas.
Reply
Thread Thread Starter Forum Replies Last Post
Help!!! trying to figure out 87 s10 fuel delivery will start ether or pouring gas in godrocksus1 Chevy/GMC Small Trucks Forum 1 03-22-2010 09:50 PM
1976 C10 w/ 350 - Fuel Issues usedgoldfish Chevy Silverado/ GMC Sierra Forum 0 11-23-2008 04:43 PM
Fuel delivery...frustrated SUPERDUTYNKY Ford Heavy Duty 1 11-07-2008 04:58 PM
Classic 1976 GMC High Sierra Pickup - $1150 sessofiore Vehicles for Sale 0 06-06-2008 04:47 PM
Fuel delivery Freemoe Chevy Silverado/ GMC Sierra Forum 1 09-14-2007 05:59 AM
Tags
1976, 76, bowl, carburetor, chevy, delivery, float, ford, fuel, gas, gauge, gmc, jumps, lines, problems, sierra, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
