vibration when under load at high speed
Old 07-06-2011, 11:41 PM
nw chev's Avatar
Default vibration when under load at high speed
1999 silvy 1500 4.3L 5spd 2wd 160k
newly developed decent vibration (rattling coins in the ash tray) that occurs only when on the gas and at highways speeds. disappears completely when i let off the gas.
i'd appreciate some advise on this.
i can see movement in one knuckle in the first u-joint (next to trans) so i am sure some of the needles have vaporized. that one is definitely bad.
thanks
Old 07-06-2011, 11:54 PM
Silverick's Avatar
To replace the U-Joint is fairly straight forward and yes, a fairly inept backyard mechanic could do this repair. The center bearing is called a "carrier bearing". Grab onto the driveline and see if anything moves within the carrier. If not, lube it up.
As far as the shocks..... replace them all!
Old 07-07-2011, 12:00 PM
nw chev's Avatar
carrier bearing: small amount of movement, seems to be just the rubber flexing, no clicking type of noise.
Old 07-11-2011, 01:05 PM
nw chev's Avatar
neighbor helped with what turned out to be an almost trivial R&R of the u-joint next to the trans. no more vibration, yeahhh!
98white5.0
29
04-12-2009 07:48 AM
Fishn
07-18-2008 11:53 AM
billcallen
07-17-2008 11:25 AM
RepairmanSki
12-12-2006 02:55 PM
wienerwater
04-02-2006 03:38 PM
Quick Reply: vibration when under load at high speed
