1997 c1500 v6 swap to v8
Old 03-17-2014, 12:55 AM
David Smith's Avatar
Default 1997 c1500 v6 swap to v8
I have a built chevy 350 that i just built from the ground up and just have a few questions about a swap into a 1997 c1500 4.3l 5speed
The truck i was building the motor for is just too far gone so i want to do a v8 conversion.
Motor is a 1978 chevy 350 397010
Here are my concerns.
Motor mounts for the 4.3l are diffrent i was just going to use my 78 chevy v8 mounts (should be a direct bolt in)
flywheel/clutch 4.3l is only an 11in and 5.7l is 12in clutch/flywheel. Going to buy a new flywheel and clutch for v8 motor for the nv3500
Radiator, sensors ect... no problem taken care off already
can i use the stock sending unit/computer if i regulated it to correct psi for carb?? Im thinking stock fuel pump wont engage with out engine crank signal (run own power supply to pump???)
Those are my main concerns any help or info would be greatly appreciated??
Old 03-17-2014, 05:53 AM
poncho62's Avatar
I imagine you will have to bypass the crank sensor, shouldnt be too hard or run a new circuit for the fuel pump. A regulator will be needed for sure. Dont forget a big piece of black electrical tape to go over the check engine light, unless you are planning to disable all that computer stuff....lol
Old 03-17-2014, 09:53 AM
Yeah the check engine light isnt a big deal i will most like remove the light bulb when i do custom gauges. I want to keep the computer becasue i can still install some sensor from a newer motor like water temp, volts, and oil pressure but i will still have pods with all my mechancial gauges also.
Thanks for your relpy
Old 03-17-2014, 10:19 PM
NullHead's Avatar
You can just wire in a toggle switch for the fuel pump, or wire it in series with your oil pressure sensor just like the old TBI trucks used to do.
95chevyssbcb
11
02-29-2012 10:44 PM
FREAKZILLA
02-21-2011 02:03 PM
Shorted
01-04-2011 09:22 AM
Pliaison
04-02-2010 12:06 PM
65malibuss
Vehicles for Sale
07-19-2005 06:02 PM
Quick Reply: 1997 c1500 v6 swap to v8
