1998 Sierra will NOT run
My 1998 will not run. It had always had cold start issues. The fuel pump had signs that signaled to me that it was going out. It finally did go out. I changed the fuel pump out over the weekend and now the new one will not work either. You should be able to hear it kick on, correct? They are pretty foolproof to install, so is there something else that could keeping it from starting?
Thanks in advance.
Thanks in advance.
I would say that the pump needs to work slightly harder if the filter is bad, but you'll possibly just end up with less fuel pressure at the fuel rail. So, yes. That was my next question, did you replace the fuel filter?
I have purchased one, I just need to put it on. I am just trying to figure out why my new fuel pump won't work.
Disconnect the fuel line to the engine and turn on the key and see if gas is coming out. Is it a TBI or seq rail? If TBI pull the air filter and pour a little gas in and if it fires for a moment you'll know it's a gas problem. I had a 91 chevy that blew the fuse that powered the pump and the clutch in the auto tranny. The 700R4 tranny clutch wires were shorting out blowing the fuse. It was a 5 amp but a 10 amp would work OK. I found it when I changed the tranny filter. Just a thought.
I did pour a little gas in and it sputtered then died, so it is indeed a gas problem then.
jswordy
23
07-18-2022 07:54 AM
louisianaoutlaw
04-19-2014 08:50 PM
billie
03-10-2009 12:33 AM
young_gun
02-16-2007 10:16 PM
