Turn Signal Issue
Old 12-30-2010, 02:30 PM
Zabman14u's Avatar
Default Turn Signal Issue
i have an '04 sierra, 2500 HD. 6.0L, crew cab, 6' bed, electronic telescoping mirrors and approaching 90K miles. and i have an issue with my left turn signal. at times lately, my left turn signal has been acting up. when i flip it on, i get both turn signals going off at the same time as if i had turned on the hazard lights. the right turn signal has not had this problem. the hazard effect also turns off after a turn as if it was functioning perfectly fine as a normal turn signal. this is not a problem that happens all the time however. some times, i when i turn it on and they act up, i just turn it back off and back on again, and it works fine. once or twice in the last few weeks that did not fix it and i just gave up and the next day it was kinda working again. id say about 75% of the time, they function correctly and the other 25% they do not.
has anyone else encountered this problem before? thanks in advance.
Old 12-30-2010, 04:11 PM
chrisbmo2000's Avatar
sounds like one of 2 things is happening: A: the left signal has a ground problem and it is "searching" for a ground or B: the signal switch has an issue internally and needs to be replaced.....option A is cheaper and easy to check.
Old 01-04-2011, 09:33 AM
Zabman14u's Avatar
thank you for the reply. how would i go about checking the ground? is it in the steering column or more in the area of the markers? i have never tore apart anything inside the cab
Old 01-04-2011, 08:19 PM
The grounds are out at the lights. If you are gonna start digging into wiring you might as well check ALL the grounds to ALL the lights. I have been known to cut the grounds and "give" it a good ground, just because. Had to do this on my old body style truck once.
Harland
03-16-2012 09:30 AM
lear_eric
01-31-2010 06:44 AM
72charger
9
08-09-2007 06:40 PM
makeminegaited
07-03-2007 05:24 PM
slemmer
01-05-2006 01:48 AM
Quick Reply: Turn Signal Issue
