6.2 gas engine bogging down when accelerated to the floor
Old 08-24-2014, 11:16 PM
Kyle Megginson's Avatar
Default 6.2 gas engine bogging down when accelerated to the floor
not sure if this is the correct place to post this bt i have a 2012 ford f350 88k miles when I oush the gas pedal to the floor it will take off for a second then start bogging down and all the valves start clattering sounds awfull. check engine light came on and flashes when its bogging code reads cyl 8 mis fire, I have put a coil pack and injector on # 8 didnt help any suggestions ?
Old 12-01-2014, 02:21 PM
tomsr's Avatar
I hope you got your truck fixed by the time you read this. I just joined the forum. Had the same problem and it was hydraulic lifters floating when the engine was revving. Sounded like the pistons were swapping holes.
fallingup693
01-22-2012 06:29 AM
Mazdaspeed
10-21-2009 10:04 PM
liquidflame802
01-02-2009 10:04 PM
nakins
06-05-2007 06:15 AM
singletoy
03-12-2007 11:43 PM
Quick Reply: 6.2 gas engine bogging down when accelerated to the floor
