O2 Sensors changed - 2001 Silverado 1500 4.3L
Old 09-03-2021, 06:25 PM
Rex Smith's Avatar
Default O2 Sensors changed - 2001 Silverado 1500 4.3L
2001 Silverado 1500 4.3L v6 - 350k miles...
I drove from Dallas to Houston - then back to Dallas again... last weekend After I got back to Dallas - the next morning - my Check Engine light was on - so dropped into a local shop to have them quickly read the code(s). O2 Sensor - Bank 1, Sensor 2.
I went ahead and bought a set (RockAuto - Surprisingly was delivered next day by DHL!) and replaced both downstream sensors. Check engine light is still on. So - do I need to have it reset by the shop? I tried unhooking the battery for a few minutes - but didn't clear it. Or do I just need to drive - and eventually the light will turn off after so many minutes/miles on the road? Ive seen videos where some models have to "relearn" that there's a new oxygen sensor... Would that be the case on my 2001?
With some luck - maybe this will help my gas mileage issues I've had over the last couple of years, also...
Old 09-03-2021, 07:12 PM
Rex Smith's Avatar
3 trips.... 2 around the block, then the last - a longer trip to the grocery store. CEL is off. Case closed (for now). I'll anxiously watch my mileage.
Old 09-27-2021, 10:59 PM
Rex Smith's Avatar
I wound up changing all 4 O2 sensors - since the upstream sensors affect fuel trim. Also changed the pcv valve. My first complete tank of gas improved mileage immensely! This tank got 22.4mpg. note also - this was a road trip (highway miles), and I kept the cruise control at 74mph or less, and use ethanol-free 90 octane.
The following day - I drove another tank of gas - however no cruise control because of heavy traffic, and was at 75-85(ish) mph. Mileage on THAT tank was right at 11.8 mpg. 😳. Lead-foot = bad mpg!!!
Old 05-10-2022, 04:04 PM
thomasv's Avatar
Thanks for the advice guys! I was just thinking about changing the sensors on my dodge and upgrading the engine a little. I found a good resource here 5.7 HEMI RAM Upgrades, where you can find a lot of parts for a full or partial upgrade
tailtank
03-09-2013 10:35 PM
Saltdome
08-25-2010 10:52 PM
greythunder
03-26-2010 01:06 AM
cnewbold
10-11-2009 09:41 PM
sedersteeler
07-25-2008 06:14 PM
Quick Reply: O2 Sensors changed - 2001 Silverado 1500 4.3L
