How much gear oil in rear diff
Old 10-06-2013, 12:39 PM
Thomas Troop's Avatar
Default How much gear oil in rear diff
Hello,
I'm doing some pre-winter maintenance this weekend. I want to replace the rear diff oil and gasket. I plan in using Mobil 75W-90 synthetic gear oil. My question is how many quarts do I need? Saw some you tube vids on an older Silverado and he used not quite 3.
Thanks,
Tom
Old 10-06-2013, 02:24 PM
They're right. Some diffs take a little over a quart and a half. Other diffs take a little over 2 quarts. No matter what diff you have... Fill up to just under the filler hole and insure that your dif vent is clear and unobstructed
Old 10-07-2013, 09:36 AM
Mine took just under 3. I had 4 ounces left over in the last in the last bottle.
Side note: PB Blaster is your friend.
Old 10-07-2013, 09:48 AM
Prometheus2508's Avatar
When I did fluid swaps on my truck, the front diff, rear diff and transfer case all received fluid until it just started to overflow. Be sure to remove the old gasket completely, scrapping off any remnants or crusted debris for a proper seal.
dkramber
02-02-2011 09:37 AM
ALFONSO318
06-21-2009 01:32 PM
greythunder
30
09-12-2007 08:15 AM
shaved88
04-03-2007 11:17 PM
vetteboy86
02-11-2007 05:25 AM
Quick Reply: How much gear oil in rear diff
