AFM/Active Fuel Management - 2008
Old 09-22-2008, 10:10 AM
hochhaus's Avatar
Default AFM/Active Fuel Management - 2008
Does anyone know if the frequency of shifting from V4 to V8 can be adjusted. Specifically when I'm on the freeway and the road has the slightest incline, I would like to stay in V4 mode longer to conserve gas.
I have the 5.3L engine.
Thanks!
Old 09-22-2008, 11:46 AM
rxsteven's Avatar
Default RE: AFM/Active Fuel Management - 2008
You might be able to have it adjusted with a tune Give Nelson a call and they will tell you.
Old 09-22-2008, 12:53 PM
hochhaus's Avatar
Thanks - Nelson said this is not possible.........
Old 09-22-2008, 07:52 PM
rxsteven's Avatar
That sucks!!
Old 09-23-2008, 08:57 AM
jcbst12's Avatar
Yeah they can either turn it off or leave it go. Nothing else.
Old 09-23-2008, 05:13 PM
moose's Avatar
I have a 2008, 5.3L also. As far as I know, it can't be changed. It would defeat its purpose, if you could change it.
Old 09-23-2008, 08:24 PM
Actually there are quite a few things a tune can change including shift points, fan engage temps, etc.
As I understand it the V8 mode is set from the factory to engage at 6% throttle position, but it can be changed to 8 or even 12% to help stay in 4cyl mode on flat roads..
I'm working to verify now if there's someone in the DFW area that can do this for me. I'm also trying to verify if it will compromise my warranty in any way.
I'll report back after I get some better answers..
Old 09-25-2008, 08:17 AM
jcbst12's Avatar
I heard the V4 only makes a difference in flat areas. The AFM does not make a huge difference in our area from what I can tell.
Guy form Pittsburgh here has a tuner on his 08 Silverado (its a trinity tuner, nice a hell! Monitors engine parameters while driving) anyway, he says with the tune and the AFM removed (turned off) he gets the same MPG as stock with the AFM on.
MIZZOU1
04-27-2009 05:07 PM
MikeMac
05-27-2008 03:55 PM
Helomaniac
02-22-2008 10:04 PM
OC Silverado
12-11-2007 11:09 AM
dk1ben
10-08-2007 07:35 PM
Quick Reply: AFM/Active Fuel Management - 2008
