Headers Or 410 gear
Old 06-20-2007, 09:22 AM
jester's Avatar
Default Headers Or 410 gear
Iown a 2007 Chevy Silverado 4.8, which headers would give me the most lowend tire spinning horsepower. I have already installed the superchips programmer, cold air intake, andflowmaster.I think this would be the next step. How hard are they to install?Or should I save my money for a 410 gear?
Old 06-20-2007, 09:59 AM
Default RE: Headers Or 410 gear
headers are easy to install. but watch out depending on your exhaust you may loose some low end power. 4.10 gears are gonna be a lot harder to install.
Old 06-20-2007, 12:33 PM
jester's Avatar
Ya, the 410 gearI would have to haveinstalled, but the cost is $800.00! IfI would lose lowend power with the headers the 410 gear sounds like the best power increase.
Old 06-20-2007, 04:16 PM
you should actually gain low end with headers, but the 410 gears will definately give you better takeoff. I would go with a reprogram 1st though.
Old 06-21-2007, 09:19 AM
jester's Avatar
What do you mean reprogram? The hand held superchips programer? The only option that is different is axle size.
Old 06-21-2007, 06:26 PM
MrLM7's Avatar
A custom tune is the way to go. A handheld programmer is okay, but a custom tune is the ****. As far as headers go, get some PaceSetter longtubes.
Old 06-21-2007, 06:32 PM
Yeah that's what I meant a cutom PCM tune, not the hand held programmers.
Old 06-21-2007, 10:17 PM
DamnYankee's Avatar
You might also consider some Doug Thorley headers. I'm not sure if they make them for a 2007, but they're designed to maintain or increase bottom end torque with the Tri-Y design. Others, including Pacesetters will usually lose you a little low end torque but give better mid-top end.
Old 06-22-2007, 07:26 AM
jester's Avatar
Sounds good guys thanks for all the help!
ALFONSO318
06-21-2009 01:32 PM
Apple man
9
05-14-2009 05:53 PM
jester
10
11-20-2007 09:05 PM
XoTedoX
01-14-2006 12:13 PM
sierra94
12-17-2005 11:27 PM
Quick Reply: Headers Or 410 gear
