front end noise
front end noise
I know what the intermediate shaft noise sounds like and i got used to it. but, today a clunking noise is coming from theleft front tire area. it increases and decreases with speed. any one have suggestions? it does it intermittently and especially when i am turning to the right. And it is audible from the exterior of the vehicle too.
thanks
thanks
RE: front end noise
ORIGINAL: Argon
2 wd?..maybe a loose brake pad...see if it goes away when you ease on the brake..
loose shock...swaybar...
I also thought the shock because it sounds the same as when i had a broken one on another car. but the question i have for you is would the truck still handle the same if it was broken?
also i have tire wear on the outside of my passenger front tire only maybe this will help in the diagnosis.
how should i check these parts out other than the obvious visual and shake it inspection?
RE: front end noise
i am an unbeliveable dumbass!
I was taking off the tire to check the caliper and found that last time i took the tire off, i only tightened 2 of the 6 lugs. needless to say, the noise is gone now that they are tight again.
thanks for your help.
