fuel problem
Old 07-28-2014, 07:24 PM
altonlee's Avatar
Default fuel problem
I have a 1994 chevy pu 5.7. Starts and runs good, takes off good but when it warms up about 30 minutes or 20 or so miles it will not do over 50 and sometimes less.
I have changed fuel pump, throttle body, fuel regulator twice, fuel filter and new plugs and wires.
Still acts like is running out of gas at high speeds.
Any help woulp be appreciated.
Old 07-28-2014, 11:45 PM
Are you sure it's a fuel supply issue? or even an ignition issue?
Are you getting a check engine light or have you had it read for codes?
I'm thinking a transmission issue and your ECU is causing a Limp mode
Old 07-29-2014, 07:59 PM
NullHead's Avatar
Plugged catalytic converter? Pull the o2 sensor and try again, just remember that it'll be loud
ecarri100
01-09-2011 09:54 AM
chrisbmo2000
12-24-2010 03:35 PM
needshave
01-24-2010 12:53 PM
jrk99
12-07-2009 11:57 PM
mhughes299
11-09-2005 12:35 PM
Quick Reply: fuel problem
