How to disconnect ABS? - Page 2 - Truck Forums
Reply
Thread Tools Search this Thread
  #11
Old 11-28-2011, 10:30 AM
How can I clean/replace the ABS sensors? Where are they located? Are they hard to find?
  #12
Old 11-28-2011, 11:22 AM
NullHead's Avatar
yeah I highly doubt it's your tires. Has to be an ABS system malfunction. The only time an ABS system kicks in, is when one of the sensors detects one wheel is slowing down faster than the rest of them. For example, if your foot is on the brakes, and a single tire slides in water or ice, the abs kicks in to let hydraulic pressure out of that wheel's brake line. This would, in theory, keep the tire from sliding, and help keep the vehicle under control.
Your tires aren't the issue if your ABS is coming on when it isn't supposed to, and you aren't sliding.
  #13
Old 12-04-2011, 08:53 PM
Quote:
The wheel speed sensors are in the wheel bearing. They are easy to replace, but they are expensive. You'll spend about $100 for just the sensor, while a new wheel bearing is about $140 and comes with a new sensor in it.
Reply
Thread Thread Starter Forum Replies Last Post
ABS Light- No ABS GMCSierraFan Chevy Silverado/ GMC Sierra Forum 4 04-25-2011 04:38 PM
fuel pump quick disconnect fuel lines needshave Chevy Silverado/ GMC Sierra Forum 0 01-24-2010 12:53 PM
Air Bag Disconnect BirdDooHead Chevy Silverado/ GMC Sierra Forum 0 09-18-2008 10:35 PM
Gas Gauge no longer works after battery disconnect. hawks General Motors Tech 0 08-01-2008 11:48 AM
fuel line disconnect tool montero91 Ford F-150 Forum 1 05-15-2006 10:47 PM
Tags
06, 2000, 2001, 2006, abs, chevy, disconnect, disconnecting, ford, gmc, s10, silverado, size, tire, truck, trucks, unplug, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
