leaking AC HP/LP ports (no valve .. sealed?) - Truck Forums
Reply
LinkBack Thread Tools Search this Thread
Old 05-06-2010, 07:43 PM
Default leaking AC HP/LP ports (no valve .. sealed?)
Im hoping someone here might be able to point me in the right direction.
Last year i was working cleaning up the engine bay on a 2002 silverado 5.3L.
I uncapped both the HP anbd low pressure ports (just the plastic caps) to clean them ... and noticed 2 things .. one leading the the next.
1st it sounded like a very small leak when i removed the cap (small pop on removal) on the forward unit (high pressure i think) and unlike any other AC i remember instead of a valve within .. it looked like small sealed hole.
After toying with the cap .. the only time it leaked was with the plastic cap off .. little soap and water to be sure on how small the leak was .. and if it was leaking with the cap on.
Now a year later while the wife was driving it looks like it blew the cap off and and seems to have dropped most of the oil and refrigirant (guessing).
It still has some pressure on the line .. small hiss .. but it definately blew the cap completely off and vented a LOT.
Whats the recommended way to check .. and replace it. (or even just the AC level). Manifold gauges wont attach to it that way
If it doesnt have a schrader valve to seal that port... why have it there at all? unless there something special im missing .. and if it did leak and blow out the seal that was there .. guessing the entire line needs replaced
*edit*
Well i stand corrected.. i appears to actually be a valve but not a replaceable schrader type .. so if that seal if kaput ... then entire unit line had to be replaced... or so it appears at this point
Old 05-06-2010, 09:45 PM
Actually it will unscrew and is replaceable. It is the high side and I just had one leaking on my Suburban. It does not look like it unscrews, but it does and they are famous for leaking. I picked mine up at O'reilly's for like $10.00. Good luck!
Old 05-22-2010, 05:23 AM
I know this is an old thread but for future reference here is what I did when facing the same problem on another truck. I was have the same issue, the AC worked fine but it leaked around the high pressure AND low pressure ports. I went to John Deere and bought ports for a 4960 tractor! It is heavy duty and made of solid brass. I paid 40 bucks for both the high and low side. I never had another problem..
Old 07-02-2010, 03:04 PM
I'm having the same problem with my 99 Suburban TD. The dealer replaced the entire assembly because it was leaking and now this one is leaking. Do you know if the ports for the 4960 tractor will fit my 99 GMC Suburban? If not, how do I size it to do what you did? How did you figure out that the 4960 was an exact fit? Thank you in advance for your assistance.
Old 07-04-2010, 07:42 PM
It should be the same on ALL 134 AC systems. At least all the ones Ive seen are.
Reply
Thread Thread Starter Forum Replies Last Post
How to grease your sealed hubs Greaser New Member Area 23 02-22-2014 06:17 PM
V10, 3 valve or 2 valve klr650goldwing Ford Heavy Duty 0 02-11-2010 12:24 PM
leaking fuel biker3777 Chevy Silverado/ GMC Sierra Forum 0 11-18-2008 11:44 AM
Rear Window Leaking or Removal BirdDooHead Chevy Silverado/ GMC Sierra Forum 0 09-08-2008 06:32 PM
Leaking Fluid unit731 General Motors Tech 2 07-23-2007 12:48 PM
Tags
1997, ac, chevy, gmc, high, hiside, leak, leaking, leaks, parts, pressure, schrader, side, silverado, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
