Leaking whee bearing?
Old 01-03-2014, 11:14 AM
Moose95030's Avatar
Default Leaking whee bearing?
Happy New Year All!
I was washing my 2003 slverado 2500hd 2wd and noticed some grease splatter in the passenger side rear wheel well. Is this a bearing a seal gone bad? I would like to fix this myself if I can, any recommendations?
Cheers!
Old 01-03-2014, 06:36 PM
NullHead's Avatar
I highly doubt any grease from the wheel bearing would ever leak out ... it's a sealed hub on that truck. I'd say it's possibly brake fluid from the caliper, or something dripping down in there from higher up (the engine, radiator, etc)
Old 01-03-2014, 10:27 PM
Rear axle seal.
Old 01-04-2014, 03:50 PM
NullHead's Avatar
Whoops, didn't notice it was the rear wheel.
Old 01-04-2014, 03:57 PM
poncho62's Avatar
Drum or disk brakes?
Pull the wheel and drum and inspect......if disk, it will be all over the rotor if the seal is leaking. If the seal is leaking, chances are the bearing is toast. Can you hear anything (gravelly sound)?
GLS0628
10-09-2014 07:44 PM
Whitaker24
01-19-2009 06:57 PM
biker3777
11-18-2008 10:44 AM
BirdDooHead
09-08-2008 05:32 PM
unit731
07-23-2007 11:48 AM
Quick Reply: Leaking whee bearing?
