OBDII not working
OBDII not working
So my SES came on and my scanner won't power on when I plug it in. I tested the scanner on another vehicle and it works. I checked pin 4 and pin 16 on my truck's OBDII plug and there is no voltage. Is there a fuse in line somewhere? Has anybody else had this problem?
RE: OBDII not working
there is a fuse but I dont remeber where it is if I remember right it is a 5amp fuse....I would check ALL your fuses with a test light....I think it shares a fuse with something else its been awhile since I have seen this problem
So the wiring diagram shows that the data port is connected to power with the cigarrette lighter. My lighter socket does not have power. I checked the fuse panel on the driver's side but the fuse for the cig lighter is not on the diagram. Is there another fuse panel where the fuse is located?
