P0405 EGR Sensor A Circuit Low - Truck Forums
Reply
LinkBack Thread Tools Search this Thread
Old 12-04-2008, 09:30 PM
Default P0405 EGR Sensor A Circuit Low
Greetings! Have a 1999 Sierra Z71 with 5.3L engine, last winter service engine light would come on when engine was started when very cold only. Check of codes showed P0171 and P0174 fuel system lean bank 1 & 2, after posting determined fuel pump pressure low, replace MAF, EGR valve, fuel pump, fuel filter, & fuel pressure regulator over course of several weeks attempting to fix . This improved problem but didn't completely go away. By time all of this had been done it warmed back up and no problems since. Since it has turned cold again recently, had service engine light come on when engine was cold and sometimes after this happens it will idle fine but surges in 15-40 mph range. At highway speeds it runs fine. Rechecked codes and found P0405 EGR sensor A circuit low. Truck has factory engine heater and when it is plugged in overnight problem doesn't occur, but when parked at work for entire day and then started cold it will trip. Suggestions on possible places to look to solve problem? Any help would be appreciated! Thanks!
Old 12-05-2008, 06:56 AM
Default RE: P0405 EGR Sensor A Circuit Low
your chronic lean problem may well be the intake gaskets.
as for the egr,you'll have to follow a flow chart step by step...they can be tricky
Reply
Thread Thread Starter Forum Replies Last Post
2006 4.8 1500 Silverado Emission Vent sol/cont circuit bigbass78 General Motors Tech 1 08-05-2012 01:47 AM
99 F350 Diesel - Check Engine Light - P1393 Glow PLug Circuit Low Imput - Please Help Gooseguy84 Ford Heavy Duty 3 07-02-2012 05:34 PM
egr valve or egr solenoid problem 95gmcss Chevy Silverado/ GMC Sierra Forum 3 04-25-2012 04:18 PM
Charging circuit problem imns New Member Area 1 05-01-2008 03:23 PM
egr valve and oxygen sensor sueb Ford Heavy Duty 0 08-14-2006 08:07 PM
Tags
1999, 53, 99, chevy, circuit, code, dodge, egr, exhaust, gas, low, p0405, recirculation, sensor, sensors, sierra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
