power steering problem
Old 04-21-2007, 02:01 PM
chevy112488's Avatar
Default power steering problem
my power steering cuts in and out sometimes... it will be working, then i hit the brakes and go to turn and all of a sudden im cranking on a 55 chevy... is there any chance i broke something cheap?
Old 04-21-2007, 02:27 PM
Argon's Avatar
Default RE: power steering problem
whats it on?...does it have hydroboost?
Old 04-21-2007, 03:04 PM
its an 02 silverado 4.8... i have no idea what hydroboost is
Old 04-21-2007, 06:45 PM
superddd's Avatar
I haven't seen a hydroboost on anything smaller than 1ton......
Old 04-21-2007, 06:49 PM
im pretty sure there is a sensor that shuts off the p/s above a certain speed maybe that is faulty
Old 04-21-2007, 08:49 PM
Hydroboost is a is a brake system that uses power steering pump pressure to provide power to the brake system. The easiest way to tell is to look at the brake master cylinder. If it does not have the big drum vacuum boost unit between the firewall and the master cylinder, but instead there is a unit there that has pressure hoses running to the power steering pump then you have hydroboost .
Cheers
Old 04-21-2007, 08:53 PM
i dont have hydroboost, and i'm pretty sure myp/s pump is cutting in and out, so i guess im gona have to fix that... thanks for the help
Old 04-21-2007, 08:54 PM
I had a 04 Avalanche 1500 that had it. I couldn't tell that it was any better than the vacuum type.
Old 04-21-2007, 10:22 PM
Argon's Avatar
Ok,no hydroboost..yes,that pretty much sums it up to a bad pump...a tricky,but not impossible repair
Old 11-27-2008, 01:27 AM
O yea.. Changing it isn't fun! make sure you get a good pully puller. One without stripped threads on the bolt! Have some extra power steering fluid too and its really easy until you have to remove the pump. The angle has to be exact to get it in AND out. Only part that will **** you off. Promise
turcotw
9
12-19-2017 02:11 PM
Houlihan
07-13-2011 02:08 PM
rdanelz
01-25-2009 06:49 PM
Cvtsax
02-15-2008 09:26 PM
usmc223
08-13-2007 09:46 AM
Quick Reply: power steering problem
