1992 GMC Sierra 1500 1/2 ton 350Engine
Old 06-16-2008, 10:10 PM
92gmcowner's Avatar
Default 1992 GMC Sierra 1500 1/2 ton 350Engine
okay i own a 92 sierra with a 350 racing engine in it, this vehicle was given to me by my employer, and before i moved out to my new home i was only driving about a total of 16 miles per day, thats it, now the distance is about 30 miles total per day,okay my problem is this, the engine has been overheating alot and i dont know what to do else, i have replaced the thermostat to a 180 degree, i have replaced the radiator and i have replaced the ground sensor and i have also replaced the water pump, so im open to any ideas please help me out, you canemail me on here or at my personal email: Lawnman321@hotmail.com
Old 06-17-2008, 08:52 AM
Default RE: 1992 GMC Sierra 1500 1/2 ton 350Engine
possibly head gasket. Check the oil and see if there is any coolant in it.
Old 06-21-2008, 08:30 PM
GMCTRUCKS's Avatar
Member
Check you fan clutch first check for signs of oil around it also check it see if you put on fan blade backwards check to see if they sold you the right water pump some flow in a different direct than others use 1 gallon of anti-freeze then fill the rest with distilled water maker sure yor radiator istoped offalso check over flow tank make sure it has anti-freeze you first want to start from the small stuff first before you start sinking a lot of money in it that you don't have to. Let us know what happens. Good luck! GMC
Old 06-23-2023, 06:02 PM
Chas2b's Avatar
If nothing seems to work after it warms up have some one watch and as you rev the engine see if you have a collapsing hose
Chrisskaraudio
06-16-2020 11:12 AM
jtd120663
10-07-2014 07:51 AM
cobra139
11-08-2011 11:55 PM
02camarossle
10
06-02-2010 10:03 AM
drzoid
02-05-2008 08:58 PM
Quick Reply: 1992 GMC Sierra 1500 1/2 ton 350Engine
