Replacing front hubs will ABS problem come back ?
Old 10-08-2008, 12:06 PM
Sierra2002's Avatar
Default Replacing front hubs will ABS problem come back ?
I am faced with dreaded replacement of the front hubs because of "Slow speed ABS activation" on my 2002 Sierra with only 32K miles. A trust worthy shop said they would be replaced with hubs that have "Timken" brand wheel bearings for $1020, lifetime gaurantee on the hubs. My question is won't the problem come back after they get rusty also? The shop guy said "The aftermarket is aware of this problem and their replacemnts are not subject to that happening again, the sensors are riveted to the hub, the tab that holds the sensor down is plastic". Well I think on my vehicle the entire sensor is also plastic and is bolted to the hub at one of it's ends.I can't see how it wouldn't return, hubs rust, sensor air gap increases, and your right back to square one. Are hubs a part that needs to be changed a lot, every time this problem occurs? Unless the hub has been plated or some how coated to keep it from rusting I can't believe any replacement hub no matter what it's brand wouldn't have this problem again?
Old 10-08-2008, 04:23 PM
Argon's Avatar
Default RE: Replacing front hubs will ABS problem come back ?
if your in the rust belt..wisconsin,michigan,etc...its gonna come back,yes
Old 10-13-2008, 05:11 PM
WIZARDSWORKSHOP's Avatar
do not replace hubs and waste your money there is a service bull Subject:Antilock Brake (ABS) Activation at Low Speeds (Clean Wheel Speed Sensor Mounting Surface) #03-05-25-007C
http://www.gm-trucks.com/forums/inde...icle&id=65
truck72454
10-24-2012 02:19 PM
kenard660r
01-24-2012 06:41 PM
skatafrata
06-24-2011 09:35 AM
truckasaurus
05-01-2010 08:10 PM
newtonmachine
03-27-2009 09:41 AM
Quick Reply: Replacing front hubs will ABS problem come back ?
