Replacing the slide-out towing mirror on a 2008/2007 Sierra
I've actually got a 2008 Silverado but I know it's the same as the Sierra so I thought I might have better luck getting a reply if I posted my question here.
I clipped my slide-out tow mirror on the side of the garage the other day and it broke the glass on the lower "blind spot" mirror and broke the mount on the larger upper mirrorfor my 2008 (same as the 2007) Silverado. The glass on the upper mirror didn't break. Also, the actual plastic mirrorhousing isn't broken, but if I can find one at the junk yard, I'm thinking it will be easiest to just replace the whole mirror assembly.
Can anyone tell me how to do this? I've seen muthco.com has some good instructions but I could only find it for the standard smaller (non-towing) mirrors.
Can I just remove that plastic triangle piece on the inside of the door (does it just pop out), or do I need to remove the whole door panel?
If I replace just the broken pieces, instead of the whole assembly, can I do it without taking the door apart? How do I do that?
Any answers you have would be very helpful and much appreciated!!
Thank You!!!
Thank You!!!
lortech
13
03-07-2014 01:11 AM
Piper316
08-08-2011 02:26 AM
catchmohl
09-01-2007 04:44 PM
