leveling kit gone wrong?
Old 12-27-2014, 09:29 PM
2004chevy's Avatar
Default leveling kit gone wrong?
I just had a leveling kit put on my Silverado.. All looked good.. A few days later i noticed the back of the truck was crooked. My passengers side was higher than the drivers side by a little more than a inch.
Any ideas why?
Thanks
Old 12-27-2014, 09:35 PM
mbogosia's Avatar
Is the front equal heights on both sides? Also you might get on the phone with the manufacturer of the kit you used and see what their thoughts are.
Old 12-27-2014, 10:43 PM
primem's Avatar
what was installed...front keys and rear blocks?
make sure the rear blocks haven't shifted...hopefully they didn't stack blocks.
did you get it aligned afterwards?
Old 12-28-2014, 05:15 PM
2004chevy's Avatar
Yes both front sides are the same. I just don't know what would cause this.
Old 12-28-2014, 05:21 PM
2004chevy's Avatar
Front shocks and keys and rear blocks and shocks. Nothing was stacked. Thats why im just baffeled by this. And yes it was aligned after the install.
Old 12-28-2014, 06:16 PM
I would be interested to hear what the manufacturer has to say about this issue too
Old 12-31-2014, 07:19 AM
2004chevy's Avatar
Default re arch
I have a2004 Silverado 1500. I need to get my leaf springs re-arched. Does any body know where i can get this done near Holland mi.?
Old 12-31-2014, 09:26 AM
Is Suspension King near you? Almost any suspension dealer can do this for you.
Most of these look like they only work on big rigs, but they can look after our trucks too
Old 01-01-2015, 10:11 PM
mbogosia's Avatar
I love a lifted truck as much as anyone but I've stopped lifting mine or putting on bigger tires. Seems like the truck is never the same after that.
Old 02-08-2015, 01:11 PM
TMW's Avatar
TMW
TMW is offline
If your truck had equal heights side to side before the leveling kit was installed I suggest you look real close at the springs and block and make sure each side is installed the same. That all bolts are tight. Check the spring to make sure none are broke. You said the height appeared to be OK after the kit was installed. A small difference in block size makes a big difference in ride height. If the spring bolts were not tightened right the passenger side block nipple may have lifted out of the hole making that side higher. The shocks have nothing to do with ride height, they only dampen the spring action.
CNukem
06-03-2013 12:12 PM
01hd1500
12-15-2007 08:06 PM
Mcfly
06-14-2007 07:00 PM
clix813
11-21-2006 02:30 AM
bro1972
02-23-2006 05:51 PM
Quick Reply: leveling kit gone wrong?
