Water Pump leak
Old 01-21-2006, 03:35 AM
KS Z71's Avatar
Default Water Pump leak
Howdy Y'all. I just had an inspection done on my 99 Silverado and they told me that my water pump is leaking. I was wondering if any of you could tell me where the most common leaks occur on a water pump (they didn't say where). I mean do I need to replace the entire pump or could it just be a gasket or seal somewhere???
Old 01-23-2006, 09:43 AM
Default RE: Water Pump leak
replace the pump
Old 01-27-2006, 04:19 AM
If it is a gasket leaking, the pump is likely fine, but if you are taking it off anyways.....Also, if the water is coming out of the pump drain, it needs to be replaced. Either way it is coming off of there.
In2Trux
04-19-2015 08:50 PM
98fordf154.2
05-31-2011 05:42 PM
kingofboulder
07-31-2010 07:32 AM
silverado99_1
06-04-2008 04:09 AM
deadwood144
9
12-07-2007 04:32 AM
Quick Reply: Water Pump leak
