Dodge Dakota Forum Discuss the Dodge Dakota here.
95 dodge dakota
Old 09-25-2014, 06:22 PM
roberthd's Avatar
Default 95 dodge dakota
I have a 95 dodge dakota when its idling and have hood open i can hear air building up then it stops then check engine light comes on does any one know what that is? thanks
Old 03-31-2015, 07:53 PM
mrdarcy's Avatar
Could be an idle air control valve, that's the device that controls fuel-injected vehicles like your 95 dodge dakota to regulate the idle speed of your engine. It's controlled by the engine's computer, it's a bit complicated so can consult this for more info, hope it helps. In any case, i'd have a trusted mechanic do the work to be sure. Good luck.
Old 04-01-2015, 11:20 AM
Before anything, I would go down to autozone and have them pull the codes for you. This will help point you in the right direction.
As I have found with my Honda, A lot of times a gunked up throttle body can cause erratic running and throw false codes, so I would start by cleaning everything up
da1shyguy
05-21-2010 09:37 PM
da1shyguy
10-02-2006 07:47 PM
da1shyguy
10-17-2005 02:21 PM
gmfod
09-27-2005 05:18 PM
da1shyguy
06-05-2005 01:00 AM
Quick Reply: 95 dodge dakota
