Dodge/ Ram General Tech Dodge tech talk within.
1993 Dodge Caravan won't shift ?
Old 02-14-2011, 12:41 PM
Tom Nicholl's Avatar
Angry 1993 Dodge Caravan won't shift ?
This grand caravan is in 2nd gear it is driveable but it won't shift. It's a 3.3L engine and a 604 transmission.
Old 02-14-2011, 04:50 PM
Worf's Avatar
By wont shift do you mean that the shifter is stuck in 2 or that the auto tranny wont shift passed second?
Old 02-14-2011, 09:35 PM
The transmission starts out in 2nd gear and will not shift to 3rd gear. The gear shift handle is not the problem.
Old 02-15-2011, 07:39 AM
Worf's Avatar
Ok since you are sure it is not the selector in the van or the linkage itsself then here are a few more
1. make sure you have the proper level of tranny fluid
2. It may be a Faulty fluid pump if the tranny isnt getting enough pressure it isnt going to shift.
Does reverse work ?
if both of these check out then i would suggest unless you have experience with automatic transmissions it would be best to take it to a tranny shop. Auto trannys are quite complex inside.
Old 08-16-2012, 01:10 AM
nelsee's Avatar
Banned
Check out the transmission it would be helpful for you to start up again.
NHJack
16
08-25-2021 06:38 AM
Oatmeal256
08-21-2012 03:39 AM
J Brown
08-04-2011 06:52 PM
derbytruck129@aol.com
04-05-2011 10:09 AM
SouthBayZ71
8
09-20-2007 12:28 PM
Quick Reply: 1993 Dodge Caravan won't shift ?
