Dodge/ Ram General Tech Dodge tech talk within.
oil pressure 98 dokota 5.2
Old 12-01-2008, 04:23 PM
jay211's Avatar
Default oil pressure 98 dokota 5.2
ok i have repaced the oil pump and bearings when drivin it is about 35 psi but when you stop it drops to 0 and this is pissing me off because if any of you have changed a pump in one of these trucks you would no why
Old 12-10-2013, 07:49 PM
daisyjohn's Avatar
Unless your oil pressure is dropping too low, this is not a problem nor is it unusual. On a cold engine, upon first start-up, the engine goes from 0 oil pressure to a high oil pressure, because the oil is cold and thicker. As the engine and oil heat up, the oil becomes thinner and the pressure goes down. This is normal.
Old 12-10-2013, 08:37 PM
A 2008 post... I'm sure the engine has been recycled and melted do to make ball bearings for my grandson's little red wagon
acsudberry21
01-18-2012 10:46 AM
ElectroJoe
08-22-2011 03:21 PM
dansZ71
12-10-2006 02:05 AM
CFM
11-11-2006 10:01 PM
all4macs
01-14-2006 09:56 PM
Quick Reply: oil pressure 98 dokota 5.2
