Go Back   Truck Forums > Dodge Truck Forums > Dodge General Tech
Sign in using an external account
Register Forgot Password?
Search
Reply
LinkBack Thread Tools Search this Thread
Old 03-08-2010, 12:17 PM
Default white smoke coming from exhaust
hello, I would really appreciate it if someone can help with my question. I have a 2003 dodge ram 1500 8cylinder 5.7. I have to have my catalyc converter replaced, could this be the reason for the white smoke coming from exhaust? What is the best converter to purchase for my year/model?
Thank you
This ad is not displayed to registered members.
Register your free account today and become a member on Truckforums!
Old 03-08-2010, 03:46 PM
Member
Quote:
Thank you
The last time I had white "smoke" coming from my exhaust I had to get a headgasket job done on the engine. I really hope this is not the case here.
Old 03-13-2010, 08:02 PM
Quote:
I hope that is not the case that sounds costly, but thanks for your input.
Old 03-14-2010, 07:57 AM
Worf's Avatar
Send a message via MSN to Worf Send a message via Yahoo to Worf
I agree white smoke normally means blown head gasket
__________________
1999 Ford F150 Ext Cab 5.4L 4x4
"Winner best truck 90's Modified"
2011 Sierra Vista Cars in the Park
2010 Sierra Vista Cars in the Park
-PM me if you need anything-
Old 04-12-2010, 03:49 AM
Banned
headgasket jog is first option, & secondly may be change with latest from company dealers.
Old 07-21-2010, 04:06 AM
Banned
When the vehicle is idling walk around the back by the exhaust if you can not smell oil burning or do not notice a sweet smell do not worry about it. If you do notice a sweet smell it is because you have antifreeze leaking into the exhaust system either from a bad head gasket or a crack in the head or block. Hope this answer helps
Old 10-29-2010, 01:41 AM
Is the white smoke was come before you replace the converter?
Same problem i have in my 2006 dodge, the white smoke come at the time of morning when I start my truck. After 10 min it stops coming white smoke because of engine warms up.
__________________
Pickup trucks
Old 12-27-2010, 01:12 AM
Banned
Head gasket is blown dude, no doubt about it. common issue with them. if you want to keep the truck, put the stud kit on the head to eliminate that, then install the EGR bypass kit...
Old 02-22-2011, 04:53 AM
Kindly check rings in the engine whether worn, if it is then needs to replaced, or may be there is problem with head gasket, check the same.
Old 02-22-2011, 09:36 AM
honestblades's Avatar
Member
It could be either a head gasket or an intake gasket. Regardless of which one is the culprit,it sounds like you have water in your engine.
Reply
Tags
150, 57, changing, dodge, exhaust, nissan, plugs, ram, smoke, smokes, spark, start, titan, truck, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Advertising
Internet Brands, Inc.
