Go Back   Truck Forums > Dodge Truck Forums > Dodge Ram Forum
Sign in using an external account
Register Forgot Password?
Search
Reply
LinkBack Thread Tools Search this Thread
Old 06-04-2006, 04:58 PM
Default OBD connector location
I have a '94 Ram 1500. The "check engine" light came on and I went to a parts store to have the code read. I couldn't find the connector. I checked under the dash on the driver's side, then the passenger side, then under the hood around the fuse block, then in the cab by the fuse block, then I removed the lower dash panel on the driver's side. I could not see the connector. Is it hidden somewhere or connected to a dummy holder?
This ad is not displayed to registered members.
Register your free account today and become a member on Truckforums!
Old 06-13-2006, 01:46 AM
Default RE: OBD connector location
On my 95 v10 it is in the engine compartment, right in front of the passenger, coming out of the harness at the top of the firewall. But ---turn ign key on-off-on-off-on and count the flashes of the check engine light. one flash pause two flashes means code 12 which means your battery has been disconnected within the last 50 ign key on cycles. Five followed by five is 55 means end of code display. If you get other codes write them down in the order they were displayed and come on back here or google them to find out what they mean. Alex
Old 06-13-2006, 01:49 AM
By the way did not mention that your truck is OBD1 not OBD2 so the zone probably won't give you much. Alex
Old 06-16-2006, 01:30 PM
the connector on the 95 is not the same as the 94. 1994 was still OBDI, which means that you have to do the "key trick"...there is no plug-in reader.
__________________
Old 04-21-2012, 01:51 PM
how do u figure out what the numbers mean?
Old 04-23-2012, 01:53 AM
Ya please mention whether its OBD1 or 2. Have you tried key off method retrieve the codes? I think that might help.
Old 04-23-2012, 06:24 AM
Its an obd 1 on a 95 ram 1500. I did do the key thing and got the codes 37, 27, and 32. I dont know where to look to see what the #'s stand for. Thanks
Old 07-11-2012, 03:13 AM
you should have the old chrysler connector next to the fuse panel under the hood or near the computer. any garage with the snap on scanner exspecially the old red brick one will have this connector and yet it will only give you a code and maybe a little bit of data.
__________________
Used Heavy Duty Trucks
Reply
Tags
1500, 1994, 2006, 94, 95, connector, dodge, gmc, hookup, located, location, nissan, obd, ram, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Advertising
Internet Brands, Inc.
