OBD1 Codes "How to pull with code list" Dodge
For vehicles made after 1996, retrieving the codes of the check engine light in your dash panel is simple. All you need to do is find your diagnostic connector located under the dash by the driver side. You can then hook up a scanner and the codes will be displayed for you. If you don't have any scanner like most drivers, you can bring your vehicle to any local automotive store and they will usually scan the codes FREE for you.
However, for vehicles made on or before 1995, there is only one cheap way to get it: You do it yourself!
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the engine light. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.
Dodge trucks have a diagnostic trouble code retrieval method, Unlike Gm and Ford trucks the Dodge line of trucks has no data port connector to gather codes from.
Instead Dodge has a ignition cycle activation sequence that anyone can active by turning the ignition key on off in rapid succession five times with the cycle ending in the "on" position.
Once this activation has started the check engine light will start to flash. The first set of check engine light flashes will be the first digit of the two number code. After the check engine light pauses for a short time it will start to blink again starting the second digit identification and completing the code's second number. If additional trouble codes are stored in the computer the first digit will begin to flash, and then the second digit. For example: the check engine light flashes four times, pauses and then flashes three more times the code is 43.
The check engine light will flash one and then two meaning the code gathering is over. The system will only flash 12 if there are no codes stored in the computer’s memory. To clear codes disconnect the negative battery terminal for 30 seconds and reconnect.
Below are the OBD DTC's for 1995-previous model year EFI-equipped Dodge vehicles.
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle position sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 waste-gate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects over-boost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
Import Car Code Definition
1 oxygen sensor
2 crank engine sensor
3 air flow sensor
4 barometric pressure sensor
5 throttle positioner sensor
6 motor position sensor
7 engine coolant temperature sensor
8 no.1 cylinder tdc sensor
12 air flow sensor
13 air temperature sensor
14 throttle positioner sensor
15 sc motor position sensor
21 engine coolant temperature sensor
22 crank angle sensor
23 no.1 cylinder tdc sensor
24 vehicle speed sensor
25 barometric pressure sensor
31 knock sensor
32 manifold pressure sensor
36 ignition timing adjustment signal
39 oxygen sensor
41 injector
42 fuel pump
43 egr
44 ignition coil
52 ignition coil
53 ignition coil
55 iac valve position sensor
59 heated oxygen sensor
61 transaxle control unit cable
62 warm up control valve position sensor
55 end of message
66 no ccd messages
1 oxygen sensor
3 air flow sensor
12 air flow sensor
31 knock sensor
39 oxygen sensor
41 injector
42 fuel pump
43 egr
44 ignition coil
52 ignition coil
53 ignition coil
DivotMaker
03-31-2011 01:32 PM
