Losing water
Old 01-23-2011, 07:12 PM
RIGWELDER's Avatar
Default Losing water
I have a 08 f350 6.4 its losing radiater coolant from cap at 65 mph an above but still holds pressure having to put coolant in it every other day been in 2 dealerships they dont know any help would be appreciated bad part is i have strong mech background ha ha
Old 01-24-2011, 04:06 PM
Worf's Avatar
are you sure it is comming from the cap ??
Old 01-24-2011, 09:02 PM
RIGWELDER's Avatar
Default Radiater cap
Worf im not sure how to pm but hopefully you see this im 100 percent sure its the cap where its losing fluid as long as i keep it under 65 dont seem to do it pass somebody ill wet there windsheild its the cap
Old 01-25-2011, 07:41 AM
Worf's Avatar
well i guess we can start out with the simple stuff....
have you tried replacing the cap ?
Old 02-01-2011, 02:52 AM
AbleSmith's Avatar
Banned
If this is the problem of flushing the water from radiator then you may need to replace the radiator, kindly check the hoses are securely clamped to the radiator and are not leaking, and still problem persist take it to the mechanic.
Old 02-01-2011, 07:12 PM
RIGWELDER's Avatar
Default radiater
worf i replaced cap stiill doing it a guy told me i might have cracked head gasket just not big enough for the test to pick up about ready to junk it and buy a dodge [did i say that]
In2Trux
04-19-2015 08:50 PM
Kushog
11-23-2011 05:47 AM
bbwalker
04-28-2008 09:40 AM
4500_degrees
11-18-2007 05:44 PM
Pr1m3
09-12-2006 12:55 PM
Quick Reply: Losing water
