Exhaust Ticking
Old 09-17-2014, 04:16 AM
Ronniek's Avatar
Default Exhaust Ticking
Hey, my 5.4L 06 F-250 4x4 has developed a exhaust leak over the last 6 months getting worse. I crawled under it & fired it up (remote start) & it sounds like it's coming from where the Passenger side header pipe goes into the exhaust pipe & it looks like where a Doughnut Gasket would be. BUT! Two parts houses & the local Ford Parts house says their computer doesn't offer a Doughnut Gasket. I tried to tighten & it's tight.
Has anyone had issues with this part/area? Or is the leak probably a exhaust manifold gasket?
Thanks,
Ronnie Knight
Old 09-17-2014, 05:53 AM
poncho62's Avatar
Usually a ticking sound in the exhaust is one cylinder leaking....I would look for a cracked manifold where it attaches to engine
Old 09-19-2014, 09:26 AM
The thing with a leaky, ticking exhaust is it is hard to pin point the exact spot were it is leaking without fiscally feeling the leak.
You still can ad a gasket to that flange joint. BUT you may need a torch to heat those flange nuts to loosen them.
Another common area that ticks in your exhaust system is at the exhaust manifold (Header). Sometime a manifold bolt will snap off at the front of the manifold or at the back of the manifold.
jsech
06-29-2009 09:27 PM
bhsballer76
02-04-2009 11:11 PM
topwhop
02-27-2008 02:22 AM
yokalryder
12-15-2007 08:04 PM
Chevy_5150
03-04-2007 03:37 AM
Quick Reply: Exhaust Ticking
