Go Back   Truck Forums > Ford Truck Forums > F-Series Tech > Ford F-250 Forum
Sign in using an external account
Register Forgot Password?
Search
Reply
LinkBack Thread Tools Search this Thread
Old 09-17-2010, 06:38 PM
Default F250 Transmission/shifter indicator
I have a 2002 F250 AT 4WD. It is acting a lil' funky with shift/gear indicator.
There seems to be a lot 'slop' with column shift lever. In D,,, the indicator is to the far right of the D,, you can free move it to the right side of N. Maybe not a big deal,, but at times it is hard to find drive and even reverse,, you have to rock the shifter back and forth to find sweet spot. I do plow some snow, not much but some,, so the shifter/linkage has more than the 69000 miles on it. So,,,, could it be sloppy linkage,,, there seems to a small lever or pivot at the bottom of steering column,,,, could that be worn ???? Maybe just order one of those,, can't hurt to replace it ???????
Once in gear [ r or d ] all seems fine,, no herky jerky,,, moans or groans,, or slow or sluggish shifting,,,,, r and d are just hard to dial in ,,,,,, Any ideas ???
This ad is not displayed to registered members.
Register your free account today and become a member on Truckforums!
Reply
Tags
2002, column, drive, f150, f250, find, ford, gear, hard, indicator, linkage, shift, shifter, transmission, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Advertising
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
