Has anyone had or seen this steering problem?
I have a 2005 f -250 super duty 4X4 super cab 5.4 gas motor conventional vacuum power booster w/ power steering. trying to find out if anyone has had or seen this problem I have a very intermittent problem ( once or twice in four days when turning back from a right hand turn only the truck steering wheel jerks to the left then when you try to compensate I turn steering to the right wheel then jerks to the right jerks to the right ( will not return to center acts like some is real loose but have had vehicle checked front end tight no stress fractures on the frame all mounting brackets firmly connected to frame all front end steering ball joints tight & no binding found has new steering dampener & had a loose right outer tie rod neither concern changed my initial issue with the steering I was told it is a bad steering gear box Would like to make sure before putting out a large chunk of change for the gear box
thanks
KC Steve
thanks
KC Steve
under construction
12-14-2006 01:52 AM
