Misfire Problem
Old 05-08-2011, 10:40 PM
oilfieldtrashet's Avatar
Default Misfire Problem
I have a 2001 F250 with the 6.8L V10. My truck has 177300 on it. I had all the plugs and coils changed a couple weeks ago but I am still getting codes that say that cylinder 3,4 &7 are misfiring. Have brought it in to a couple repair shops they have checked for vacuum leaks they have checked the coils the problem clears up for several days then it comes back. Has anyone had this problem before.
Old 05-09-2011, 10:08 AM
geomath's Avatar
Lightbulb misfire
* The firing order is : 1-6-5-10-2-7-3-8-4-9 The 1 thru 5 cylinder are from front to back on the passenger side while 6-10 are from front to rear on the drivers side.
* You have cylinders 3, 4 and 7 misfiring
* the only common component I can think of is the spark distribution
* or maybe you have three bad wires
Old 05-10-2011, 08:50 AM
I was thinking the wires I was hoping someone would say it was something else I hate wiring problems because it can lead to other problems
Old 05-10-2011, 09:34 AM
geomath's Avatar
Lightbulb distributer?
I am not familure with the spark distribution for the V10. Does it use the traditional cap and rotor or is it computer controlled
(i.e. distributerless)???
I ask because maybe the fix is in the distirbution. If there is a cap and rotor, try checking those and maybe replacing just to see if it fixes it.
I was looking and found this web page about the Triton series in general
Consumer complaints about Ford Engines - Spark Plug Defect
You might be interested in some of the comments on this page.
One more thought. Autozone has a reference library online and I found this on ignition systems there; Ignition System
Good luck
Old 05-11-2011, 08:02 AM
I have the coil over plug not the distributor. I am a mechanic friend when we come in from work next month we are going to pull the engine out and go through it we will find the reason for the problems thanks for your help
Old 11-02-2011, 06:06 AM
spoonracer111's Avatar
i have a similar problem except mine is on cylinder 3 i believe i havent checked it in a while but i remember it throws a code for a random misfire and says bank one is running lean i have changed out the plugs the wire and the coil and i still cant figure it out im at a loss but it runs and drives so i said screw it and im still driving it but having it fixed would b nice
Mr_Shamrock
07-07-2009 09:11 PM
02bowtie
04-26-2009 03:46 PM
98white5.0
29
04-12-2009 07:48 AM
JLusive425
05-15-2008 05:13 AM
96burbo
07-23-2007 05:19 PM
Quick Reply: Misfire Problem
