1999 F350 6.8L V10 No Code miss
Old 04-23-2012, 06:04 PM
99F350V10's Avatar
Question 1999 F350 6.8L V10 No Code miss
My 1999 F350 6.8L V10 has a slight (and what seems to be intermittant) miss. My code reader (Innova 3100) returns no errors, however. Any ideas on what I can test next? Here is what I've tried so far . . . .
(1) Installed new spark plugs.
  • Although the plugs that were removed were that old, I replaced all of the plugs with new ones after properly gapping each per Chilton's manual.
(2) Performed fuel pressure test.
  • Fuel pressure with key on and engine off equals 34 psi, which is within the recommended range specefied by Chilton's manual.
  • The leak-back <2 psi in 5 minutes (well within spec).
  • With engine running, fuel pressure dropped to 28 psi (normal).
  • Acquired resistance readings on fuel injectors (all within 11-18 ohm range as specified in Chilton's manual).
(4) With engine running @ ~1500rpm, coils packs unplugged one at a time.
  • Each time one of the coil packs was unplugged, there was a noticeable change in engine performance. This led me to conclude that each coil pack and plug was indeed working fine.
I did receive a comment from another shade tree mechanic about a a possible fault in the computer board. But I do not know how to test this, or even where it is located on the vehicle. Any advice here?
proyotehunter
01-16-2013 01:02 AM
proyotehunter
07-10-2012 12:18 PM
graw506
09-15-2011 03:26 PM
otowniron
05-04-2011 03:21 PM
Eastfrisian
11-05-2008 04:30 AM
Quick Reply: 1999 F350 6.8L V10 No Code miss
