Cold start issue
Old 11-12-2013, 05:46 PM
PredatorC6's Avatar
Default Cold start issue
My 99 F350 diesel will not fire when the temp is below 40 degrees. Warmer than that and it fires right up.
Is there a sensor that may not be working that would richen the mix for cold temperature starting?
Also, I thought most (all) diesel trucks came with an engine heater. Can't find the plug on this one? Any thoughts? Could it be optional?
Thanks.
Old 11-13-2013, 01:25 AM
I'm assuming you don't have any codes or check engine light..
So I have to ask, are you getting a glow plug light on your cold start?
Are you allowing your glow plugs to fully cycle to do their job before you start your truck.
Old 11-13-2013, 06:20 AM
PredatorC6's Avatar
Correct... No codes or CEL. Wait to start glow plug light seems to be functioning properly. I'm thinking it may be a coolant temp sensor that has failed, and the EMC may think the engine is warmer than it really is ???
I'll change out the sensor and see if that helps.
Thanks.
1993GMCSierra
09-22-2011 08:10 AM
izod
02-06-2009 01:38 PM
DoMeStIc_FaN
02-06-2008 05:09 PM
stopspazinout
15
08-07-2007 10:06 PM
lightorch
09-16-2006 07:30 PM
Quick Reply: Cold start issue
