How to replace throttle position sensor
Old 07-20-2010, 07:13 PM
SnaggS's Avatar
Default How to replace throttle position sensor
I have a 90 f350 5.8L and started out with losing spark so i replaced the plugs, wires, coil, ign. module, and then after replacing the distributor(and getting it top dead center on the #1) got it to run, but it runs with a real bad surge or hiccup..so then i adjusted timing to see if i could get it better(even checked to see if i'm 180 out), no luck. Took it to a mechanic to do a diagnostic and they said it showed a misfiring problem, but didn't provide me with codes. So I replaced the fuel filter also..replaced map sensor.....Could it be the T.P.S.??? And how do i replace it? Please Help!
Vinnymac16
11
03-26-2014 09:37 AM
Worf
GM How-To's and Tutorials
04-11-2010 05:08 PM
Worf
Dodge/ Ram How-To's and Tutorials
04-11-2010 05:02 PM
Worf
Ford How-To's and Tutorials
04-11-2010 04:56 PM
popo
07-21-2007 04:41 PM
Quick Reply: How to replace throttle position sensor
