Rotors
Old 07-09-2013, 04:08 PM
WGS's Avatar
WGS
WGS is offline
Default Rotors
On our 2003 F350/7.3, when purchased in 2008 I had the brakes done and they turned the rotors. In 2010 I had to have the rotors replaced, In 2012 they had to be turned again. Now I'm getting the same vibration as all the other times. First off I've drove semis most of my life and I know how to use brakes and I've never caught a truck on fire or had any type of brake failure.
Our truck is used on our farm and if its not towing a stock trailer or horse trailer its carrying feed or hay. This truck is ran a lot in mountain areas and gets about 6k miles per year. Our trailer that is used most of the time has a light weight of 10K, and loaded is 14-15K. I also use compression as much as possible when coming off hills.
My question is has any one found a better rotor for these trucks other than the stock ones.
stopspazinout
14
02-26-2009 09:13 PM
bluepony65
04-22-2007 03:03 PM
8.1_HD_2001
03-14-2007 11:39 PM
tundra2002
11-08-2006 09:25 PM
Scott
09-13-2005 11:01 PM
Quick Reply: Rotors
