Ford General Tech Ford tech talk within.
1978 f250 rear springs
Old 11-04-2014, 12:29 PM
ducky65's Avatar
Default 1978 f250 rear springs
hi, my brother has a 78 f250 4x4 with broken leafs on the rear.we know where a good set of springs are off of a 78 f350 two wheel drive but cant get to it to measure the length.i've tryed looking them up to see if they interchange butt cant find anything .does anyone know if they will fit. thanks
Old 11-05-2014, 09:33 AM
It should work. the 3/4 ton and one ton rear leafs can be interchangeable as long as your not taking from dually
1999-2004 Ford F250SD, F350SD 2wd 4wd - Leaf Spring (Rear - 4/1 Leaves)
Model: 43-1261
by Mulitple Sources
5/5Read Reviews
A 25"
B 33.1/4"
C 7.7/8"
no. leafs 4/1
D 2.1/4" Pack Thick
Spring Cap. 3000lbs
3/4 one ton single rear wheels, two stage
Years: 1999, 2000, 2001, 2002, 2003, 2004
Model: Ford F250SD, F350SD Pickup 2wd 4wd Single Wheel
Hope this helps.
Be sure to come back and let us know how the repair worked out for you
Old 11-06-2014, 12:48 PM
ducky65's Avatar
thanks for your reply.the springs turned out to be from a dually. but were getting a set made from a local small 4x4 shop that we forgot about he is even making them stronger than when new
aDcAT 13
05-25-2021 01:34 AM
Macaia
04-01-2013 03:28 PM
legacy
04-11-2007 11:24 PM
aDcAT 13
06-21-2006 05:55 PM
bmac
Automotive Parts Wanted
05-19-2006 01:08 PM
Quick Reply: 1978 f250 rear springs
