Ford How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
How to unlock a frozen engine
Old 04-01-2010, 03:25 AM
Worf's Avatar
Default How to unlock a frozen engine
Step 1. Remove all spark plugs
Step 2. Fill the cylinders with Diesel fuel put plugs back in
Step 3. Let it sit for about 2 weeks.
Step 4. Take out the plugs, using the crank pulley nut attempt to manually turn the engine over. If it dosnt move put the sparkplugs back in a try leaving it be for another week.
Step 5. When you do get it moving freely turn it over by hand until you have most of the diesel out of the cylinders.
Step 6. Install new spark plugs, change all the fluids and a new strong battery. Add a little fuel in the carb and see if it starts on its own.
If the engine started then you are fine, but if it didnt start or even try then there is something else wrong with the engine.
If the engine is running, you will notice it's may not be running real smooth, and is blowing a some blue smoke out the exhaust. This is normal, unless it keeps smoking after all the diesel has been burned out of the engine.
Worf
Dodge/ Ram How-To's and Tutorials
11-20-2012 08:13 AM
Worf
05-27-2011 03:26 PM
Worf
GM How-To's and Tutorials
10-04-2010 02:15 PM
Ripoffrock
03-15-2010 06:58 AM
brian46227
12-24-2007 07:40 PM
Quick Reply: How to unlock a frozen engine
