05 chevy 4x4 2500 silverado transfer case - Truck Forums
Reply
Thread Tools Search this Thread
Old 08-15-2010, 07:36 AM
DEW DEW is offline
Unhappy 05 chevy 4x4 2500 silverado transfer case
My truck started making a loud clunking noise from somewhere underneath. It sounded like the transfer case. It was only at low speeds or when I let off the accelerator. On my way home something gave out and made a horrible clunking ( not quite grinding noise). Pulled over and it wouldn't move. I tried revving it up, every gear and every position in four wheel drive. When I put it back in park it still made a noise like something was trying to engage ( very LOUD rattling or fast paced clunking). The truck has 117000 miles on it. There was no difference in power or torque before this happened. I towed with no problem with my wife's Ford Windstar. Any help would be greatly appreciated. Thank you
Old 06-29-2011, 02:57 PM
don't know how this works but did you figure out what was wrong with transfer case silverado? mine suddenly makes very loud metal on metal noise occasionally and seems like the front end is driving even though 4x4 not engaged
Old 06-30-2011, 04:49 PM
DEW DEW is offline
Default Transfer case
There is a pump inside the transfer case and it eventually wears a pinhole in the casing and the fluid will only leak while it is under pressure. So there won't be any puddles under your truck. There is a aftermarket spacer that can be installed and it is a harder metal than the case so it won't wear. I'm still not sure why the factory doesn't install the spacer. It cost me $1200 to get my t-case rebuilt, but I pulled it and took it in. Hopefully you caught yours in time and may not be so expensive.
Good luck,
Dustin
Old 09-06-2011, 07:02 AM
If you feel spacer is costly outside you can buy them online on E-Bay, which will cost you less
Reply
Thread Thread Starter Forum Replies Last Post
2002 2500 HD transfer case removal AndyP Chevy Silverado/ GMC Sierra Forum 1 12-30-2010 06:27 AM
97 2500 no 4WD transfer case OK no power to front axle? mulscomanagement Chevy Silverado/ GMC Sierra Forum 0 09-11-2010 12:12 PM
05 chevy 4x4 2500 transfer case DEW Chevy Silverado/ GMC Sierra Forum 0 08-15-2010 07:44 AM
99 2500 possible transfer case issues gunner99 Chevy Silverado/ GMC Sierra Forum 1 02-24-2010 01:50 PM
transfer case stuck in 4x4 Rosser Chevy Silverado/ GMC Sierra Forum 4 08-13-2006 10:19 PM
Tags
05, 2500, 4x4, case, chevrolet, chevy, clunking, gmc, noise, park, put, silverado, tacoma, toyota, tranfer, transfer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
