Dood panel removal
Old 05-15-2007, 12:12 PM
trogdor's Avatar
Default Dood panel removal
Does anyone know of an easy way to remove the front door panels on a 99 ex cab? I want to replace my speakers, but am having great difficulty getting the panels off. It has power windows/locks.
Old 05-15-2007, 02:36 PM
Default RE: Dood panel removal
yup. pull the switch panel out and unplug it. you better get a removal tool if you dont wanna mess the panel up or buy new retainers. then use the tool to pop ever retainer out. and bam its ready to pull right out.
Old 05-15-2007, 03:05 PM
Argon's Avatar
Not a 99,if its a "new" body style...The panel has no retainers...Remove 2 screws...1 under the armrest and 1 behind the lock slider..then lift the panel straight up
Old 05-15-2007, 04:35 PM
trogdor's Avatar
Thanks a bunch buddy. Yeah, it is the newer body style. What is the best way to access the screw behind the lock slider? Pop the slider out?
Old 05-15-2007, 06:54 PM
Argon's Avatar
Yes..pop out the black rectangle..pop out the trim piece around the handle...pop off the triangle piece up high...remove the 2 screws....lift up the window switch and unplug the wires..then "lift" the panel up
Old 05-15-2007, 11:44 PM
whoops thought he said 98 but yea i think its been solved here.
Old 08-17-2009, 03:27 PM
ncseahawk's Avatar
OK...OK...what about the older body style.Mine is a 99 but is a 2500 and has the older body and panels.
What is the trick.
So far I have removed the two screws on the armrest, and popped all the panel retainers but it is still very connected around the latch mechanism.
Old 08-17-2009, 08:16 PM
You have to take the trim piece that goes around the handle off. The best way I have found is by using a small plastic putty knife (it won't scratch or gouge the plastic). You have to stick it in the small crack that is between the flat plastic piece (the one that your knuckles touch when opening the door) and the outer trim. There are 2 or 3 tabs that once you put the putty knife in there you will see how it will pull straight off with the knife wedged in there. The handle and the piece that your knuckle touches will stay on the door. Hope this makes sense - Good Luck!
alan7407
09-05-2011 03:37 PM
GMCSierraFan
12-29-2009 05:03 PM
yourkiddin
05-20-2008 04:19 AM
mikes50
04-27-2006 09:36 AM
coolman1987us
02-20-2006 10:51 PM
Quick Reply: Dood panel removal
