GM How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
How to Check a Battery Drain on Your Truck
Old 04-12-2010, 02:53 AM
Worf's Avatar
Default How to Check a Battery Drain on Your Truck
Battery drain can be explained as one or more of the devices or systems in a truck malfunctioning by pulling charge from the truck battery when the engine is not running, instead of only when the engine is operating. Certain systems in a truck are designed to always draw their power from the battery, such as a the stereo clock or the computer module. These systems, however, draw very little power, and will not cause a dead battery. You will want to check and test your systems to find other battery drain to prevent a dead battery and a truck that won't start.
Disconnect the negative battery cable from the battery.
Insert the test light so that it is in the circuit between the negative battery cable and the negative terminal of the battery. This can be done by connecting one end of the test light to the negative terminal of the battery, and the other end of the test light to the end of the negative battery cable.
Take note of the brightness of the test light. A faint glow is normal. This is due to certain systems, such as the clock, running as described in the overview. A bright glow in the test light, however, indicates a battery drain.
Go to the fuse panel in the truck and begin removing fuses one at a time, checking the test light as you have each one removed. If the light remains on while you have a fuse removed, that system is OK, and you can replace that fuse and remove the next one.
Identify a system that is causing battery drain by the fuse that is removed and causes the test light to go out.
MightyMike
08-06-2012 01:52 AM
Worf
Dodge/ Ram How-To's and Tutorials
04-12-2010 02:52 AM
Worf
Ford How-To's and Tutorials
04-02-2010 03:07 PM
freakinbox
02-04-2008 08:16 PM
TONY STAR
01-12-2007 03:27 PM
Quick Reply: How to Check a Battery Drain on Your Truck
