Ford Ranger/ Mazda B-Series Discuss the Ford Ranger and it's sister, the Mazda B-series here.
worth it or no
Old 02-12-2015, 08:26 PM
progolfer1's Avatar
Default worth it or no
I know nothing about the Mazda truck. But Im about to buy one maybe and I need some advice. I am looking at an 86 B2000 with 215K on it. 5 speed ext cab. Runs and drives ok no engine noise etc. Seems ok . Just want to know is the mileage a problem with these trucks ? The truck has a few minor issues but nothing major. Just the reliability of these engines is what I need to know about. Any help appreciated.
Old 02-14-2015, 08:51 PM
progolfer1's Avatar
Need some advice please
Old 02-15-2015, 09:51 PM
Each manufacturer has their good and bad. You can have 2 of the very same trucks that came off the assembly line the same day and one could end up riddled with issues and spend much of it's life in the shop and the other be totally reliable.
On the other hand, you can buy an older truck like the one your looking at with lot of miles and still have lots of life left in it.
If your sell can show you a maintenance history or repair history If it was well maintained I would go for it.
Old 02-21-2015, 03:59 PM
poncho62's Avatar
If the body is good buy it.....Those trucks tended to rust away before the drivetrain went bad. I take it you live in a dry, no salt used on the roads climate.....lol
Old 04-13-2015, 03:07 PM
Geterdun's Avatar
Good deal! If you plan to keep it, drive it while you save/acquire a v6 eng/trans. you can probably do this for the cost of the hard to find parts for yours plus labor and machine work.
A 4.3 GM Vortec from a truck is a drop in fit. No butchery needed, use original radiator.
Not sure about the shifter location for a standard, I used an automatic. I figured 190 horses, I could get gone quick enough!
Change to a carb, and 86 HEI distributor, or get the wiring harness and computer with the engine. I did it to lose the bot in a 90 B2600 Extended cab.
thecure
07-16-2010 09:42 AM
benpfeil
05-02-2007 01:50 AM
Regal105
18
04-10-2007 12:20 AM
yannawiled
01-22-2007 01:07 AM
beefeater
12-25-2006 12:57 AM
Quick Reply: worth it or no
