Problems with Washing a Truck
I just got a job washing heavy truck(you know,for transport) . I'm having a little bit of problems on how to wash it.Ex: Do I start by the top or the bottom? or What are the spot I really need to get? Do you guys have any tips on it. I am just a teenager so I do not have a lot of experience with vehicles. It would be amazing if you guys can help.
Any truckers or drivers that can give me a hand?
Thank You and God bless,Vernon
Always start from the top and work down or you will be washing dirt from above on the area you just cleaned. I have driven a truck and the main things I wanted squeaky clean was windows, mirrors, and lights. This is obviously for safety reasons. The rest of the truck should be clean as well so the company truck looks good going down the road (advertisement). Don't clean the grease off the 5th wheel (the part that slides under the trailer and hooks to the kingpin on the trailer). This needs to be kept lubricated. Good luck with the new gig!
Congratulations on your new job Vernon.
Liston to Mr_Shamrock When I was still driven truck I wanted my wheels to look spotless too.
When I use to was my truck... I started from the top then worked my way down.
Opened the hood and washed the top of the hood. Then closed it to rinse clean.
Let us know how it goes.
also like he said mirrors windows lights and the rest
one thing i make sure are very clean is the hoses and what not in the engine compartment and on the rear of the frame be careful when doin that thow the pressure washer can puncture the hoses i use the lowest pressure tip and i hold it back about 1-1/2 feet to 2 feet
the reason i wash them parts is so the next time they pop the hood they can spot leaks easier
and congrats on the job
one more thing to avoid is the air cleaner under the hood if you get water in there it could cause engine problems
Thank you
Hello everyone and thank you guys so much for your support!
So sorry that I responded so darn late,but anyways I am using all your suggestion and my boss is really happy,and so are the truckers.
Again Thank You All
Again Thank You All
