Toyota Tundra Discuss the Toyota Tundra here.
Batery Churging Problems
Old 11-15-2011, 11:39 AM
valwatundra's Avatar
Default Batery Churging Problems
When i start the tundra, on higher rpm's its allright
when rpm's are lower it shows batery sighn on and off, if i rave it a little sighn is off, after little wile dont matter how hard you rav it it does not churge the batery, at any time when i would unplog the batery cable truck would turn off
Old 05-24-2012, 07:43 AM
johntaps's Avatar
Former Sponsor
Post
Change the battery
Old 07-28-2012, 01:31 AM
nelsee's Avatar
Banned
Your battery will be expired that is why such problem will be creating just change the battery.
Old 09-09-2012, 11:48 PM
Michaelleonel321's Avatar
Firstly make sure that all the cable's are fixed and attached properly or not loosened. If the problem still persist then there must be something wrong with your charger of battery.
Old 09-13-2012, 07:15 AM
jeslin_G's Avatar
I think you should change your battery.
