Chevy/GMC Heavy Duty Discuss your 2500 and 3500 Chevy and GMC pickups as well as the DURAMAX diesel and it's predecessors
8.1L Check Engine + Reduce Power lights.
Old Jan 24, 2022 | 05:02 PM
Socal8's Avatar
Default 8.1L Check Engine + Reduce Power lights.
  • 8.1L Check Engine + Reduce Power lights.
  • Ok...everyone. Here's one that's stumping me. Before, I describe, know that I've already thrown a good amount money in repairs and new parts at this problem.
    So, my issue is the truck running fine and out of nowhere lights up the dashboard with both the 'Check Engine' plus 'Reduce Power' lights. And, does go into a reduced power mode. Along with running real rough.
    Initially, it was giving Throttle Body type error codes. Which had ne change out the TPS three different times. And, the actual Throttle Body twice. Plus, I changed out the Pig Tail part of the wiring, as well.
    No success!
    Then, after some research, I started replacing air intake parts.Air Filter, MAF Sensor.
    Still no succes!
    The interesting thing about this problem is that it seems to happen much more frequently during cold weather. Like 40s and below???
    Anyway, looking forward to suggestions !
    Socal8
    '02, 2500HD, 8.1L, 4x4, Allison, crew cab, LS
Socal8
May 22, 2025 07:19 AM
Socal8
Jan 27, 2022 12:08 PM
Socal8
Jan 22, 2022 05:10 PM
Jakede
Nov 8, 2009 07:42 PM
glendamoss
Oct 11, 2009 10:36 AM
